Very starnge problem
Discussion in 'Home Entertainment Computers' started by speighty, Feb 4, 2009.
  1. speighty
    speighty
    Jan 17, 2007
    4,090
    83
    Castleford
    +129
    I have an htpc that i built about 5 month ago with the following components
    Gigabyte GA-M57SLI-S4
    AMD 6000 athlon x2
    4gb ram
    ATI 2600 PRO
    Im connecting to a 46" plasma via hdmi.
    Everything worked fine for months but in the last week i have noticed a slight stutter in all mkv files, blu-rays, no matter what video format or player i use.
    If i resize the player screen so i can see the video and my desktop i can see what looks like flickering and this seems to cause the video to stutter.
    This only appears when playing videos, cant see it any other time
    I dont know the best way to explain it.
    I have tried numerous drivers for the gpu, this has not helped, i have also reinstalled vista on two different hard drives with the same result.
    With a fresh install of the os all i installed were the codecs needed and still the problem is there.
    I have a feeling it could be hardware related but i will need to test with less ram and different components.
    Any help would be great.
  2. speighty
    speighty
    Jan 17, 2007
    4,090
    83
    Castleford
    +129
    Someone must be able to help.
    I have tried a different gpu with the same problems.
    I have also tried with only 1 stick of ram and its the same.
    Is there a chance that it could be the motherboard.
  3. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    What refresh rate are you using and what is the source?
    Flickering is quite often a sympton of playing back 50Hz (PAL) material at 60Hz (standard desktop resolution) or 24Hz (well actually 23.96 or something BD material) at 50Hz or 60Hz
  4. speighty
    speighty
    Jan 17, 2007
    4,090
    83
    Castleford
    +129
    I managed to fix the problem.
    There must of been a setting on my tv that didnt like my pc via hdmi, i set them back to default and now everything is ok.
