Very soft image on Sky+ menus...
Discussion in 'Sky Digital TV Forum' started by voxel, Oct 10, 2005.
  1. voxel
    voxel
    Sep 26, 2005
    75
    Hi folks,
    Posted this in Rear Projection TV's first but it's probably more suited here...
    I have Sky+ hooked up to my Samsung SP46L6HX DLP TV and the menu text looks quite soft around the edges - anti-aliased you could say. I've tried umpteen configuration settings on the TV but nothing seems to sharpen them up at all.
    Is there anything that can be tweeked on the Sky+ box to help? The only setting I have found which alters the image quality at all is switching between RGB and PAL in the Picture Settings menu. I usually have it set to RGB - is this correct? I am using a 60 quid SCART lead so I'm sure the problem isn't there.
    I didn't get this issue with the Sagem Axium HD45 I had hooked up to it previously.
    Cheers,
    V.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The bigger the picture, the softer the text will appear to be. The menu on Sky boxes is not designed to be highly defined, and it is not the best thing to use to gauge the performance of your TV. RGB is usually the best way of connecting Sky+ to a screen, although s-video comes a very close second.
  3. voxel
    voxel
    Sep 26, 2005
    75
    Cheers Nic...
    Is there any reason why the digibox doesn't have component out?
    Are there 3rd party digiboxes compatible with Sky+ that have component out?
    Excuse me if this is a naive question!
    Cheers.
  4. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    No Sky+ boxes have component out - the majority of customers wouldn't know what to do with it if they had it. It's rumoured that the first generation of Sky HD boxes will have component out, but details of those are still a little sketchy at the moment.
  5. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    They have RGBS output, which is same as YUV "component" just in a mathmatically different colourspace.
    RGBS has been used on European "scart" connectors since the mid-1980s; whereas USA and Japan used S-Video until the relatively recent arrival of "component".
    There are many scart to component convertors on the market, if you need one, the best of which is made by http://www.js-technology.com/
    StooMonster
  6. voxel
    voxel
    Sep 26, 2005
    75
    Ah, OK. Cheers...
    Am I being thick when I say I can't see a reason for someone to have Sky HD using component out? Why would someone want Hi Def if they don't use HDMI?
  7. StooMonster
    StooMonster
    Nov 20, 2002
    4,974
    Kent
    +314
    Because loads of the plasmas and LCDs sold in the last few years do not have HDMI connectors, they have component. Component is quite capable of carrying HD signal, and has done so for years in USA. However, it cannot carry a copy-protected HD signal.
    StooMonster
  8. voxel
    voxel
    Sep 26, 2005
    75
    Yeh, that's what I mean... Sky HD will use HDCP wont it?
