mredvers
Established Member
hello!
after recently moving into a new home i find myself very limited on space for a sub.
think im going to have to place one under a shelving unit in an alcove about
a metre wide and when i build the shelving/ cupboard enclosure i think im gonna have to put it in there....
anyway i am not going to be wellying it out i just need some advice for a small active sub that hopefully will be no more than 30cm high, smaller the better really.
i just want to add a bit of low end support at low volumes to a set of small bookshelf speakers. (tangent evo 4)
anyone had any experience with any of these?
yamaha yst sw012
YAMAHA YSTFSW050
ideally if something like a rel quake came up in the classifieds i would probably get that.
also any other recommendations on entry level subs that are similar size?
yamaha yst sw012
YAMAHA YSTFSW050
