Very Quick Sky + Question
Discussion in 'Sky Digital TV Forum' started by caztime, Nov 30, 2003.
  1. caztime
    caztime
    Do they take the old sky digi box when you have sky +.or can you keep it.thanks
  2. davej
    davej
    Jul 31, 2003
    85
    Sunderland
    You keep it. When you get Sky installed you're buying the box (similarly sky+, the box is yours to keep).
  3. Brian110507
    Brian110507
    caztime
    did they not offer you the chance to have your existing box installed in a bedroom or similar, they do this by fitting a double LNB to your satelite dish for a nominal £10 or so.
  4. gbmitie
    gbmitie
    Apr 25, 2001
    1,144
    49
    republic of ireland now
    +62
    sky + comes with a quad(4 outputs) lnb not a double
    gb--
