Very quick HS2 Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by bobbles, Dec 9, 2003.
  1. bobbles
    bobbles
    when you are transfering from the HD to -R can you still use the tuner?
    I ask because I currently loop sky+ through my DVDR
    Also is it possible to transfer back from -RAM to the HD using the HS2? I don't think you can
  2. Yuccaman
    Yuccaman
    Mar 23, 2003
    101
    When I'm dubbing from HD to DVD-R (as I am at the mo - Miracle of 34th Street for my neice), The HS2 output will ONLY show what's being dubbed. However, I've only got the HS2 connected to Sky+ via Scart, so don;t use the tuner itself...
    For Q2, you can copy back from RAM to the HDD, and I think at high speed too.... I've only done this once so far so cannot recall the speed setting :)
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    You can transfer to and from ram as much as you want, using high speed if at the same quality setting. You can't transfer from -r to the hard drive though due to copyright issues.
    You can't view anything via the hs2 whilst dubbing, except the dubbing itself, not even sky, hence you need a second connection from sky to the tv for use during this situation and for when the hs2 is recording from its analogue tuner and you want to view sky.
  4. bobbles
    bobbles
    Well I have an s-video connection too (for sky+) so it is not a major issue
    High speed? I thought you could only do this on the E100
    Is this high speed only for RAM?
  5. jem
    jem
    Sep 24, 2002
    527
    +7
    Yes.
