Very odd mechanical sound in lows under 30hz??
Discussion in 'Subwoofers' started by Placebo1, Mar 13, 2018.
  1. Placebo1
    Placebo1
    Jun 2, 2017
    23
    Finland
    My firned got a 12" subwoofer from a professional DIY guy. It has 12" Peerles xl and Hypex DS2.0 amp and is a 40x40cm cube. Goes down to 18hz -6db. Problem is that when playing low bass songs the subwoofer seems to have somekind of razor mechanical sound. Over 30hz bass sounds good, but under it sounds like you can hear the cone moving and some buzzing.It sounds colored and not clean at all. You can hear the same odd mechanical sound coming from the main speakers also. Crossover is set to 100hz. Does it matter what is the source you are playing from? We tried iphone 7 with bluetooth. Tv own youtube. Ps4 spotify and from imac online tone generator. What could be causing this? Sub is connect via a single subwoofer rca to the amp. Also tried different positions for the sub also. I have noticed that my own bass sounds arent as clean when playing from tv compared to computer.
  2. Ultrasonic
    Ultrasonic
    Dec 8, 2012
    453
    46
    Taunton
    +108
    Do you hear this without the sub connected?
  3. Placebo1
    Placebo1
    Jun 2, 2017
    23
    Finland
    Yes, but its much more silent.
  4. Ultrasonic
    Ultrasonic
    Dec 8, 2012
    453
    46
    Taunton
    +108
    OK, so this isn't a problem with the sub then. It sounds like something else causing low frequency distortion, which will sound louder/worse from the sub as it will output more/louder at such frequencies.
