Very non-tech newbie help please
Discussion in 'Home Cinema Buying & Building' started by capt_janeway, Sep 22, 2004.
  1. capt_janeway
    capt_janeway
    Sep 2, 2004
    308
    Kennedy Town - Hong Kong
    +11
    Just got divorced (hoorah) and decided to splash out on some gadgets....
    Is this a decent set up for a newbie or overkill?
    - Panny E95 hdd/dvd recorder
    - Mordaunt Short Speaker Premiere Plus System
    - Pioneer AV Receiver - Silver finish. AVRC-VSXD814S or should I go for the Marantz 5400OSE as seen at Peter Tyson for £199.00
    Got a Sony widescreen tv with additional centre and rear speakers at the mo but wanted to upgrade the sound.
    System will be for movies only
    Thanks for any advice :thumbsup:
  2. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    The fields of Anfield Road
    Just got my D814-s yesterday :D and so far looking very good. More than enough connections / settings to keep me occupied for a while.... Matched to a DV575A.
