Very noisy xbox
Discussion in 'Xbox Forums' started by Stampax, Aug 15, 2005.
  1. Stampax
    Stampax
    May 6, 2005
    1,398
    Northampton
    +85
    My xbox makes a really loud buzzing sound when i put certain discs in it -it used to just be most movies, but now also appears to be certain games.
    Any idea what this could be a sign of?
  2. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    The obvious assumption is that it's a problem with the DVD reader. It's making the noise as it tries to repeatedly read a part of the disk that it's having problems with. Probably it will die eventually but it's very easy to replace.
