Very low speach on some AVI files
Discussion in 'Microsoft Windows' started by dUnKle, Jul 15, 2005.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,223
    +2,261
    Im watching some AVI files using my Video - the first where very good but just come across two which have very, very low dialouge
    Its strange as these are actually bigger files than the first that I watched and seem more dynamic - almost as if 5.1 but the speach is just so hard to hear
    what could the problem be
  2. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
    Do you know how the audio is encoded - is it mp3 or Ac3?
    If its Ac3 try upgrading the ac3 codec, you may also be able to amplify the voulme within the codec settings.
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,223
    +2,261
    looking it would seem to be ac3
    what codec do i need
  4. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
  5. dUnKle
    dUnKle
    Jan 1, 2001
    15,223
    +2,261
    thank you
    works a treat
  6. dUnKle
    dUnKle
    Jan 1, 2001
    15,223
    +2,261
    Just got hold of some AVI files which are said to be in 5.1 surround sound
    However they dont play as such under MCE - just detected as 2Ch by the amp
    Can this be solved
  7. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
    AC3 can also be 2 channel, have you tried G Spot to identify exactly how the file is encoded?
  8. dUnKle
    dUnKle
    Jan 1, 2001
    15,223
    +2,261
    Blimey - note to self careful on results when you google gspot
    Anyway - the file in question is listed as
    ac3 - 448kbs (6ch)
    but only shows as 2CH when playing
    What am I missing
  9. Rambles
    Rambles
    Jul 14, 2004
    8,318
    UK
    +1,288
    oh, hmmm, not sure - all I can suggest is to check that ac3 filter is set up correctly?
  10. dUnKle
    dUnKle
    Jan 1, 2001
    15,223
    +2,261
    I think it is - will have to play about
