I need a very long HDMI lead which will connect to a projector which will be located at the back of the living room and this will connect to the Sky HD box at the front of the living room.
I would like to hide the HDMI lead underneath the floorboards, and the distance is 5 meters from the projector to the Sky HD box. Can anyone recommend a cheap long HDMI cable that is 5 meters in length?
Thanks!
Thanks!
