Very daft photoshop question
Discussion in 'Photography Forums' started by stevegreen, Nov 3, 2005.
  1. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Just resizing the original of my photo comp entry to send to the printers.
    I want to make it 10'x8' as thats the size of the print.
    Whats the best way to do it? :confused:
  2. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Using Photoshop by the way.
  3. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    Would you just use Adjustments (I think that's the correct menu) > Image Size and set it to 10x8?
  4. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Thought that but the image size is in pixels and the only one that mentions inches is document size. Are these the same?
  5. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    done the document size one and it's worked :clap:
    looks a bit poorer now tho as it's blown it up. wish i had took it in highest resolution now :(
  6. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    Maybe just send it as a full-res image for them to resize based on the dpi of their printer?
    I've not got PS on the machine I'm using and can't remember all the menu options, sorry. I'm sure it's something to do with a combination of #pixels and dpi though :-/
  7. hutters
    hutters
    Aug 20, 2003
    722
    28
    Cambridgeshire
    +28
    Probably best to send them the original image and let their image processing software/RIP do the business?
  8. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    Possibly yeah.
    It's a 3 meg file now :laugh: :eek:
    Cheers hutters, sent it now :)
  9. senu
    senu
    Aug 26, 2005
    19,348
    Denham, South Bucks
    +2,811
    Well thats sorted then.
    If you dont mind me sharing a tip for future work:You can resize image to your desired measurements, ticking constrain proportions and asking the software to resample image ensuring that you specify the dpi ( or ppi) as 150-250 ( in resolution) at least.( not 72 which is the default for screen viewing) It will probably increase the file size and not add detail but will allow minimal loss of already captured detail and enable a bigger size picture.Obviously the more detail in the original the bette but at least its possible.
  10. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    That option came up and i did resample the image, but only three options were there, i used the default, bicubic.
    Whatever that means :laugh:
  11. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    Your not using the highest resolution on your camera....Shame on you... :lesson:
  12. senu
    senu
    Aug 26, 2005
    19,348
    Denham, South Bucks
    +2,811
    :nono: Hmm... he may be did not have a big size memory card: the only excuse in the world to not use his cameras highest resolution.. Maybe next time :suicide:
  13. stevegreen
    stevegreen
    May 14, 2001
    8,745
    in my Hymer
    +921
    :blush: I know, I took that many shots in different settings and I mistakenly changed the resolution. Didn't notice until I loaded the picture in Photoshop :( :laugh:
