very confused between panny's?
Discussion in 'Plasma TVs' started by Procter, Nov 29, 2004.
  1. Procter
    Procter
    Oct 29, 2004
    32
    Can anyone help ,i come down to the decision that when i buy my plasma it will be apanny but which one !!!!
    i think the choice is between the viera 42 and the pw7 but what i wan to know is which is better ?
    Alos wheres the cheapest place to buy?
    procter :lease:
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    The viera is basically a TV (i.e. with tuner, speakers and scart connections) its based on the PW6.
    The PW7 is just a monitor with no tuner, speakers and only a VGA port as standard.
    If you have the likes of Sky then most people say go the panel route, all though you will need speakers etc, but if you already own an AV amp then im sure that will be no problem.
