very cheap mp3
Discussion in 'Headphones, Earphones & Portable Music' started by gooner#14, Jul 27, 2005.
  1. gooner#14
    gooner#14
    Jul 18, 2005
    481
    http://www.tmretail.co.uk/Promotions.asp got 1 of these as a taster to mp3 problem is its playin up and ive not got the receipt, on the packaging there was a downloadable file which you needed for xp which the missis has lost , the player was bought from martins newsagents (tm retail)if that helps?
  2. hao
    hao
    Can you be a bit more specific on "playing up". If you can plug it into a USB port it may show up as another drive to which you can drag the Mp3 files without having to download the xp file.
