very blue screen
Discussion in 'General TV Discussions Forum' started by bones, Jun 5, 2004.
  1. bones
    bones
    It's a Thomson Scenium 44RW65US rear projection tv. i've took the back
    panel off and the blue CRT is much brighter than the red & green.
    The screen is glowing blue with horizontal white lines about an inch apart.
    Everything is ok apart from that you can still see the picture.
    HELP! :lease:
  2. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    2,039
    3
    63
    +107
    If it's new, contact customer service or get an engineer out, if it was me, I'm afraid.
  3. DRGL
    DRGL
    Mar 30, 2004
    752
    Shropshire,UK
    sounds like the LOPT is over driving the blue CRT?? Not sure how these things work but if the LOPT on any monitoir is turned up to high you get flyback lines which is what you are describing........
  4. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    Is it the same on all inputs? If not check settings and input leads.
