Vertical standing DVD player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ged, Sep 25, 2004.
  1. Ged
    Ged
    Apr 29, 2002
    938
    +24
    Are there any MR players with RGB out on Scart (pref loop thru), vertical standing?
    Re arranging the conservatory and trying to de clutter :)
  2. Grimley
    Grimley
    Sep 19, 2003
    929
    4
    2
    47
    Deepest, Darkest Essex, so BEWARE!
    +147
  3. Ged
    Ged
    Apr 29, 2002
    938
    +24
    Thanks for the link, unfortunately the spec link doesn't work, I will give them a call Monday.
    Ged
  4. HouseofMu
    HouseofMu
    Jul 18, 2000
    376
    UK
    +13
    The PS2 (and the new slimline PSTwo) can be stood vertically and you get a games machine for free ;)
  5. Ged
    Ged
    Apr 29, 2002
    938
    +24
    Thanks for that, not a gamer though.
    I have seen a model from DVDPlayers, made by DK Digital model DK-367, I will give this a search.
  6. spergabite
    spergabite
    Jul 23, 2004
    46
    sony do a vertical standing dvd player - i have an old version and its very good - had it six years and it still works a treat - anyway heres a link to the new version(which i bleieve can also be mounted on the wall too)
    http://avland.co.uk/sony/dvpf35/dvpf35.htm
    You better check if it is vertical before you buy.. no MR though but you could probably get one that is oh and no scart..
  7. DVDave
    DVDave
    Did anyone buy the DK-367? It looks exactly the player i need due to lack of space, but i need to be able to play DVD-R.
  8. Ged
    Ged
    Apr 29, 2002
    938
    +24
    No, I squeezed a player from upstairs into the space created after buying a Thomson DHD4000 box and binning the Pace Twin :thumbsup:
