Vertical mounted GPU holder for case with basement fans?
PerfectBlue97
I've got intake fans in the basement my PC case sucking air in fro under the case and blowing it upwards on to my horizontally mounted GPU through a grill in the basement.
I'm looking to get one of the new 3000 series graphics cards, I really like the look of the founders edition cards and I want to vertically mount one (I've got a wide case so there will be pleanty of space between the fans and the glass), but most ofth e vertical mounts that I've seen have solid bases and would block the air flow from my basement fans.
Does anybody make a vertical mount with a mesh base, or a base that's good for airflow form underneath?
Price range - £50-£70.
alphaomega16
Wouldn't have though so due to the weight the slot has to support, don't want the card shifting at all if you can help it.
MartinH32
I got this one - seems very stable! Works fine with my bottom mounted fans. Temps never above 60degrees in the case and all the fans spin at 900.
Amazon product
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
