M
MisterPoppy
Hello everyone.
I've got a problem with vertical lines when I'm playing games (especially GT HD), watching movies browsing the XMB etc etc.
It's a bit hard to define exactly how the lines look, but I'll show you this picture. Please note that I've colored "the lines", which in the real world are slightly brighter than the rest of the picture, with brown to make them easier to spot.
I'm running my PS3 in 720p so it couldn't be interlaced lines right? I'm using a Samsung 32" R75B with a HDMI cable from EB Games, I'm not sure what brand it is but I've heard some say it's called "Booklet" or something like that, quite cheap.
My question to you is, obviously, if anyone else have had this problem and knows a way to fix it? Perhaps buying a different cable will help? Or is it my TV? Or the PS3?
Thanks in advance!
Thanks in advance!
