Vertical Lines
Discussion in 'Projectors, Screens & Video Processors' started by dbright, Sep 16, 2004.
  1. dbright
    dbright
    I just purchased a used Epson Powerlite 7550c. I hooked it up to my DVD player and it projected with pretty well except for faint grey evenly spaced vertical ines running across the entire screen. I called Epson and they said it might be the cable. I then hooked up my computer with a brand new cable and it still projected the same lines. Any thoughts on an easy fix?
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    I think what you might be seeing is called Vertical Banding which is a fairly common problem/issue with LCD projectors...it is most noticable on lightish areas of the image and especially durring panning shots...nothing you can do about it as far as I know.
    Cheers, Lee
