Vertical Lines on Samsung LE-32R41BD from DVD player
Discussion in 'Samsung TVs Forum' started by idletony, Aug 25, 2006.
Tags:
  1. idletony
    idletony
    I get noticeable vertical lines on my LE-32R41BD when playing DVD,s on my Vieta VDR-3000 home cinema system (set to RGB out). The DVD is connected via a INOX RGB only cable into scart 1 (RGB). The cable goes direct and does not link with any other equipment. I have tried other scart cables with the result that better cables seem to make the lines more noticeable.
    Other components connected are a Panasonic DVD recorder (Component video) and Pace Sky box (scart 2). I have read other threads relating to vertical lines but this only relates to the sky box which is not affected (although the picture is poor).
    I have heard and read so much about how good the LE-32R41BD is but have yet to experience this.
    Do I have the correct setup and cabling? Any help would be much appreciated.
