Vertical Lines in Ellie Advantage 250
Discussion in 'Projectors, Screens & Video Processors' started by redknag, Nov 10, 2004.
  1. redknag
    redknag
    May 18, 2004
    308
    28
    Wickford Essex
    +34
    I have just bought and fitted an Ellie Advantage 250. Screen brightness is excellent & the electric motor fairly quiet. My problem is that there is 7 equally spaced vertical lines in the screen. To my eye they are slight creases as if the material was folded before manufacture.
    I will give it a couple of days to see if they drop out, if not its back to screensuk. Has anyone else had experience of this? :(
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,215
    +3,068
    Horizontal creases are signs of the material rolling over itself where it joins the central drum. This causes a crease effect and as the thing rols up more it creases very slightly further apart. It will not go away. Better quality screens have different costruction techniques that give better image quality
    G
  3. redknag
    redknag
    May 18, 2004
    308
    28
    Wickford Essex
    +34
    That sounds reasonable, but my lines are vertical? It must surely be pre manufacture.
  4. sirp
    sirp
    Jan 20, 2002
    891
    28
    Derby
    +53
    redknag, i had that, they wont go, send it back
  5. redknag
    redknag
    May 18, 2004
    308
    28
    Wickford Essex
    +34
    Screensuk have now swapped out this screen for a new one. Its now 100% perfect. I can highly recommend both screens uk & this screen. Top notch.
