Vertical Line when Playing any ps3game
Discussion in 'Playstation Forums' started by kko1v, Nov 28, 2010.
  1. kko1v
    kko1v
    Nov 28, 2010
    2
    My ps3 was working fine last night, but i have just turned it on and loaded a game, now im getting a line on the left side going from top to bottom. It is also casuing the rest of the screen to go fuzzy.
    The screen is fine when on the main home screen, or when using iplayer and video off an external HDD.
    I have tried other games and the same fault is happing, can you confirm whats casuing the problem and provide a fix.
    Kind regards
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,615
    +6,601
    Try the standard AV input to isolate whether it is the HDMI. I presume the display is fine for other uses aside from the PS3
  3. kko1v
    kko1v
    Nov 28, 2010
    2
    Thank you for the reply, I actually sloved it by replacing the HDMI with a spare one I had and this done the trick, hopefully this will help others who have a similar fault. I did not expect it to be the cable as its been working soild for the past 4 years always the last thing you think of.
