Vertical Line (LG C9)
OLEDDoLED
Hello, this is the first time ever that i'm posting on a forum. I've posted on Twitter, talked to youtubers and LG support but their advice didn't work. Posted on Reddit but nothing good came out of that - i don't even know if people will see this post. Anyway, here's my issue.
A few days ago i have started noticing some sort of white bar at the edge of my TV - when looking at on a grey background i noticed that it's some sort of bar alongside the edge, but when i play a game that 'bar' turns into a white line.
Now, this is NOT a panel issue. I tested it out with different formats to see what happens and the result surprised me. I changed the format to 4:3 and the edges actually went along with the content shown on the display. (4:3 makes the display basically square) so i know it's not a panel issue.
Also when i come to close to the screen it disappears so i can't examine it properly but i do know that it's there.
This one problem has ruined my experience with this television, i have barely played any games and i have not watched a single movie or show since i noticed this problem. Strange enough is that i don't see this problem during the picture test.
Here are the things i tried:
Pixel refresher, twice.
Factory reset.
Unplugged the TV and pressed power button for 10 seconds.
Changing HDMI cables (it's not a HDMI issue because it's also on apps such as Netflix and Disney+)
My guess is that it's a software bug, simply because the edges aren't white on the edge of the panel itself, but the content.
mikej
I would ask in the C9 owner's thread and see if it's something others have experienced - if it isn't, then presumably your TV has a fault and you can claim on the warranty.
Do LG TVs have overscan ? It's an undesirable feature to turn on these days, but it may temporarily solve your problem and help with trouble-shooting the issue.
OLEDDoLED
It isn't a panel issue because the line moves with the content when changing format.
mikej
OK, but panel issues are obviously not the only faults...
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
