Vertical bar on Hitachi 42PMA500e
Discussion in 'Plasma TVs Forum' started by supermonkey, Aug 12, 2004.
  1. supermonkey
    supermonkey
    Hi there,
    Working fine for 6 months, my Hitachi 42PMA500e Plasma has gone back under warranty to be repaired. A vertical bar the width of a pixel has appeared two-thirds into the screen. It's not dead pixels; the bar is still illuminated but it seems that one of the colours has dropped out.
    Is this just a one off or can anyone confirm whether it's an inherent problem with that particular model?
    Thanks!
    Gutted :-(
    At least they picked it up quickly :)
  2. PLASMATU
    PLASMATU
    Jul 31, 2004
    169
    oi m readin all the post bout 500e how it ended ? what do u think caused that ?
  3. PLASMATU
    PLASMATU
    Jul 31, 2004
    169
    a guy that i know had the same problem with a purple vertical bar m waiting for his pictures what do u think may be the cause bad ventilation ? where your tv was placed ? mine its the same mobel m usin it since 25 september.
    used the split screen function a lot ?
