Vertical banding problem with HS10 & Radeon 9700
Discussion in 'Desktop & Laptop Computers Forum' started by reggs, Apr 1, 2003.
  1. reggs
    reggs
    Oct 27, 2002
    115
    Earth
    Finally solved the screen size problem with my HS10 under DVI control and now have a screen resolution of 1368 x 768 using Powerstrip on my Radeon 9700 Pro. The picture however is virtually unreadable :confused:
    There are lots of brightly coloured horizontal bars right across the screen and most of the Desktop text is distorted by them. It looks like I have the timing set-up wrongly, becuase if I switch back to a more normal resolution such as 1024 x 768, then the banding on the PC Desktop disappears.
    I also get the same bars when my PC is booting up on the DOS screens! Is this normal for an HS10 under DVI? The desktop displays fine on a monitor connected through the VGA.
    Anyone have any ideas on what I can do in order to get a stable viewable picture that doesn't have all of the coloured banding via DVI?
    I'm using the following Powerstrip settings under XP - 1368x768=1368,80,136,200,768,1,3,21,79905,7
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    try
    1368x768=1368,88,144,232,768,1,3,30,82280,7
    or
    1368x768=1368,72,136,208,768,1,3,21,79223,3094
  3. reggs
    reggs
    Oct 27, 2002
    115
    Earth
    Thanks JohnS, I tried both strings but niether seems to make much difference. I'm particularly worried that the DOS screens are also corrupt. Is this normal via DVI?
    Any other suggestions?
    I'm concerned that my Radeon is at fault ...
  4. Kramer
    Kramer
    Hi reggs.
    I rec'd your e-mail & sent a reply, but TBH, my mates PC is running Win '95 & I'm not sure if you got it or not.
    I suspect your cable may well be the suspect. DVI is picky at high(ish) resolutions.
    If your HS10 is locking onto the signal & displaying #51 or #121 (IIRC) in the menu, then it's receiving the correct res/timings etc...
    I know your DVI cable underwent some "surgery" ;) & I suspect this will cause you problems.
    Fingers crossed it's a setup issue, but I suspect it's the cable.
    Cheap(ish) way to confirm is to get another DVI cable & try that direct (albeit temporary). Cost about £27 but you should be able to sell it here for a little less.
    We may be travelling through Manchester on route to Glasgow later this week. If so, I'll be sure to give you a shout.
    I've no probs with posts/PMs here - e-mail is a bit unreliable :(
    Chat soon & best of luck ;)
  5. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Boys, would you please take a few minutes and write down here an idiots guide for me in setting up Powerstrip and its' timings. Do I set this up before I connect my Radeon 9700pro via dvi to the hs10 or what is the sequence of events please?
    Sorry to be a pain, but I really need your help.
    Rick
