Vertical banding on Panny SC-MT1 playback.
Discussion in 'Home Cinema Buying & Building' started by hannibalsmith, May 26, 2004.
  1. hannibalsmith
    hannibalsmith
    Bought the SC-MT1 and am very pleased with everything except that I can sometimes see vertical banding on the screen during playback and even when the system menu is on. It's basically a band that is lighter than the surrounding picture, particularly noticable when in a darkened room and the DVD has a dark moving background. It may even move position depending on the DVD but it's not always easy to tell.
    It's not the TV cos I can't see it when it's on Sky or the Playstation and I don't think it's the scart lead cos I got one of those £40 buggers so there should be no problems there. Maybe I've got it set up wrong somehow? Please help with this cos it's pretty anoying - once you know it's there it's very hard to forget about it. Thanks.
  2. hannibalsmith
    hannibalsmith
    What if the scart lead was so good that it was picking up lines that wouldn't normally be seen on Sky/terrestrial channels? But then whats the point in paying out for a decent scart lead? Just an idea.
