Ventilation with built in Panasonic screen
Discussion in 'Panasonic TVs Forum' started by candg, Aug 5, 2005.
  1. candg
    candg
    Aug 5, 2005
    428
    Swansea
    +16
    I have almost finished building a stud wall to build in my series 5 42" Panasonic screen for flush mounting.
    I have constructed a false wall out of 3*2 timber and plasterboard which as now been plastered. Before I finalise the whole thing I was just wondering whether to include some sort of ventilation into the structure as the screen is at present completely enclosed in the false wall. The false wall is about 5" deep. I just wondered what the feeling is on this especially as there are also central heating pipes (well insulated) enclosed behind the wall. Any tips and suggestions would be greatly appreciated. I have enclosed some pics of the nearly finished project.
    Graham
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    I'd definitely put some slots top and bottom of the wall. :smashin:
  3. gnikolaidis
    gnikolaidis
    Not a very good idea. These units output around 350W of heat mostly from the back panel side of the screen. If this heat builds up over time inside an enclosed space soon you will be frying eggs over it (not to mention the internal electronics). So in my opinion ventilation is a must, most preferably a forced air circulation system like the one used inside pc cases.
