Ventilation clearance between JVC 750 & ceiling?
mr.m
Hi Gents
I notice that the manual states 15cm/6" clearance above the HD750 for ventilation. Is anyone running with less than this? I have limited headroom where the PJ is to be mounted, and had planned to install a suspended shelf/platform for the PJ (so it would be sited upright on it's own feet rather than inverted). I had been planning a clearance of ~3" above the PJ, but will I run into trouble with less than the recommended distance? The machine would have open ventilation on all sides.
Comments welcome!
George
Apone
Hi Gents
Comments welcome!
George
Hi George
TBH i think it would be ok . However, i understand your concern. Can you not bring the shelf down a few inches instead to give you the required headroom?
My mate has a 350 on a shelf as well. If i remember, there are no ventilation ducts on top are there? I think that the hot air comes out from the front of the pj:confused:
If you bring the shelf down a little, you can use the lens shift to raise/lower the image to the screen position i think.
johnyh
Sorry to contradict Apone. But I believe most of the hot air comes out of the LHS as you face the front of the PJ. I remember this as I've sat on that side of one during a demo!
Apone
Maybe i should have been more clear:)
