Veneered MDF vs laminated plasterboard?
Discussion in 'Home Cinema Buying & Building' started by stevebez, Sep 13, 2007.
  1. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    So whats better ... two layers of 12 mm MDF (the outer one veneered) or one layer of 25mm laminated plaster board (think its 10mm PB x 5mm insulator x 10mm PB - all bonded)?
    Both to be GG'd to existing ~20mm plasterboard structure.
    Rgds Steve.
  2. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    hi steve
    gg works best sandwiched between 2 pieces of equal mass, so the 2 12mm boards would be better than 1 single heavy board, though i will check with Ted at GG...
  3. stevebez
    stevebez
    Jul 11, 2004
    493
    +13
    Howdy Matt!!
    Think I am going with the double layer mdf with GG for my application. Can anyone suggest a good woodworker to do the job for me ... I can do it but with a newborn its going to take me ... probably a year!!!
    Rgds Steve
  4. mattym
    mattym
    Jul 31, 2003
    2,116
    maidstone
    +101
    congratulations to you and your wife on the arrival of the newborn Steve!
    i dont know a good builder, well..i do, but he charges very very good builder prices...
