Velodyne SPL-800 sub
Discussion in 'Subwoofers' started by itcosthowmuch, Dec 27, 2003.
  1. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    I recently bought a Velodyne SPL-800 sub and after only 10 days working it has died on me :(
    I have been able to test another sub using my existing interconnect and power lead and all is okay.
    Has anyone else experienced problems with this type of sub?
    M
  2. tk2001
    tk2001
    Nov 4, 2001
    1,378
    48
    +36
    itcosthowmuch ,
    What exactly do you mean when you said that your sub "died on me"?
    Do you mean that it doesn't power on at all or that it does power on but there is no sound coming from the driver?
    I've used this excellent subwoofer for about a week and had no problems with it.
    Maybe the fuse inside the sub's amp has blown?
  3. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    Hi tk2001
    At first the power light was on but no sound. Now though it has no power (and obviously no sound!), although the mains lead is okay as I've tested this with another sub. If I open it up to see if any internal fuses have blown, which seems more than likely, would it void any guarantee that it has?
    M
  4. Dazed
    Dazed
    itcosthowmuch,
    If it's only 10 days old then I would suggest taking this up with your retailer rather than messing about with internal fuses etc. In fact I would go so far to suggest you demand a new one.
  5. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    Hi Dazed
    Yeah those are my sentiments.......I had made contact with my retailer as soon as it when pete tong just before christmas. They were/are on the case but unfortunately are shut until the new year and now I guess my impatience is getting the better of me!
    Glad to hear though, that I haven't been bombarded with replies about everyone else having trouble with their SPL-800.
    M
  6. Dazed
    Dazed
    I tell you what you could do. Demand a refund from your retailer, and buy my almost brand new SPL1000 which is currenly for sale in the For Sale Forum. You might even "make" money and get a better sub to boot. Bargain.
    Beautiful subs aren't they, so much boom boom, so little box box. Incredible.
  7. itcosthowmuch
    itcosthowmuch
    Nov 8, 2003
    407
    sussex
    +62
    Nice idea!
    I must admit to being amazed how much these little boxes output.....even more so after it packed up and then missing out on the sofa shaking, hee hee. I tested a mates Mordaunt-Short sub on my setup to ensure my amp was still working - boy did it lack the ooomph I had been used to.
  8. Tee Tee
    Tee Tee
    Apr 3, 2002
    125
    Shropshire
    +3
    My SPL 800 failed twice in two months! Both times it was internal fuses. They have now been replaced with slow blow type I believe, and it has worked fine since then.
  9. Kefmad Rich
    Kefmad Rich
    Feb 28, 2002
    182
    Edinburgh
    I had the same problem with my CHT- 15, so changed internal fuse from 1.6A to 2A (recommended by Redline) and no more problems.
    Richie.
  10. TT9
    TT9
    I have an HGS-15 which had this same problem. One day it just went dead.
    The problem was indeed the internal fuse, which I replaced myself upon receipt of a couple of new ones. These fuses can tolerate a higher current than the one that blew. I cannot remember exact figures now but the explanation I had at the time I believe was that the fuses installed were suited for US mains supply and would have been better changed to a higher rating before I took delivery. Something like that anyway.
    Since the change no problems at all.
    Steve.
