Velodyne CHT10 or BK XLS200
Discussion in 'Subwoofers' started by fatty_ginwalla, Nov 11, 2004.
  1. fatty_ginwalla
    fatty_ginwalla
    Need a bit of advice......
    Upgrading my old sub & have narrowed down the choice between the old CHT10 (not R) or the XLS200 (having seen the budget test review). The Velodyne I can get for around £200. It will be used in a smallish room, currently set up with B&W 601's S2 front, CC6 S2 centre & B&W Solid Series monitors as rears running from a Marantz SR4300. Im not after an extremely loud sub, just tight. It would be nice to have a B&W but i can't afford it!
    Any views appreciated!
  2. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Hi fatty_ginwalla
    welcome to the club!!!!!!
    I was also thinking of that what the Xls would be like against the velodyne, sorry I can't help you there 'cause I am looking for a new sub as well, but I am sure someone would have listen to them both
    Good luck
    Gerry
