Velodyne CHT-12R Setup
martinpeter
I've just taken delivery of this thing, and I'm very happy with the way it sounds. My problem is that I don't know what volume it's set to. I like it a little louder when my wife/kids aren't there, and set differently for different movies. However I just have the volume up and down controls, so I have nio way of keeping track where it is set to. So, when I try to change it I have to do lots of adjustment to get me back to where I was before. Any ideas?
russraff
Just press the volume up/down on the remote briefly so that you see the blue light flash briefly. This will raise/lower the volume by a set amount. So, if you always reduce the volume by 3 presses, then you will always know where you are.
Ambient Fish
Hi Martin, I own a SPL 800R, if they both work in the same manner then to find out what the volume is press either the plus or minus button and then count the flashes of the indicator for example 2 slow then 5 fast means the volume is set to 25 (out of 100) it is then quite easy to make the required adjustments.
