velodyne cht 10 owners
Discussion in 'Subwoofers' started by darren7, Feb 20, 2003.
  1. darren7
    darren7
    hi there guys and girls....
    is there a FAQ on setting these up, I have looked at all the old posts and looked at the manual....
    from the start what ???? internal crossover or direct, direct I think.
    Phase 0 or 180? dont know.
    best to leave the power on all the time no auto, I no this is correct.
    low pass crossover Know, dont really no what to set this to start with.
    any help would be a plus, velo owners please
  2. paulfd
    paulfd
    May 18, 2002
    48
    Luton
    Have a CHT 15 :D not a 10 but here's the advice I rec'd from uncle eric when I was setting mine up.
    These got the sub to something like and have now been tweaking for several days using AVIA DVD and my ears. I think it's likely to be quite a while until it's exactly what I want as someone doesn't appreciate what I consider a reasonable listening volume!
    Hope this helps
    Rgds
    Paul
  3. darren7
    darren7
    thanks for the advice, I don have the same things on cht-10, they aree named different.
    internal crossover or direct?
    phase 0 or 180?
  4. paulfd
    paulfd
    May 18, 2002
    48
    Luton
    Mine's currently on direct with phase on 0 at the moment. Waiting to be alone so I can play with the phase at a sensible level.
    Rgds
  5. petrolhead
    petrolhead
    Mar 29, 2002
    4,479
    71
    Newcastle
    +82
    I thought UE was of the opinion that 80Hz was the best place to start :confused:
  6. uncle eric
    uncle eric
    Paul has the Gallo's hence my advice. 100Hz crossover with the Gallo's works well in most cases.
  7. petrolhead
    petrolhead
    Mar 29, 2002
    4,479
    71
    Newcastle
    +82
    Ah I see. Just wanted clarification. Thanks Eric
  8. darren7
    darren7
    Think there is a FAQ needed on setting the cht-10, as there is so many people who have purchased them from the power buy.
    D
