Velodyne CH8
Discussion in 'Subwoofers' started by arn, Apr 29, 2005.
  1. arn
    arn
    Dec 26, 2003
    270
    Bury
    At the moment i am using a single RCA going into either the right or left input, is it worth getting a cable splitter so i can use both inputs? and does it make a big difference?
    Trying to get as much bass as possible :D so any other tips most welcome
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,432
    Aldershot, Hampshire
    +260
    I have a splitter cable with my cht-10 and it works fine. It doesn't improve the base imo but does help with the auto switch feature which can switch the amp off during long periods of quite or no lfe. You could just have the sub switched on all the time though during a dvd but I'm a lazy so and so :blush:
  3. arn
    arn
    Dec 26, 2003
    270
    Bury
    Yeah it didn't make any difference on the first sub i had either just wondered if it differed sub to sub.
  4. KHCC
    KHCC
    Aug 10, 2004
    256
    Kent
    +10
    Mornin'
    You could try a subwoofer platform, this can give more focus'd bass and a bit more depth.
    Try the Power Buy section Here and get in contact with Matt as he is working on a subwoofer platform at this moment that will be far better than the Auralex things that are just high density foam!!!
    Regards
  5. arn
    arn
    Dec 26, 2003
    270
    Bury
    Thanks Hayes, Your sub skint me this month though :rotfl: Got to wait till payday till i can spend now :mad:
