Velo VX10 Grilling
Discussion in 'Home Cinema Speakers' started by FunkyMonkey, May 20, 2003.
  1. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    10inch circular speaker grill from Maplin. Remove the plastic V logo cover on front of Velodyne Vx10 woofer by undoing the 4 screws, put this in place beind teh logo and screw back on. Voila - your woofer cone is protected from children and clumsy adults. Code is KS75S, see www.maplin.co.uk
    Sound was not affected in my opinion.
  2. knoxy
    knoxy
    Nov 6, 2002
    196
    Manchester
    +31
    cheers for that! think i may need some - cat hairs are a'floating around the room like crazy and they seem to get everywhere... nowhere is safe...
  3. overfloe
    overfloe
    Apr 23, 2003
    230
    16
    Newcastle
    woot! thanks for the tips.. cheers!
  4. kenlong69
    kenlong69
    Oct 24, 2002
    505
    Doha
    +6
    Awsome tip mate, I've ordered one!!
    Ken
  5. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Glad to be of help. Missus returned after few days away and noticed something different but couldn't guess what. So change in look is subtle - better in my opinion cos it's still black but you can no longer see dust and unattractive cone.
    IMPORTANT: The grille comes with a nice rubber band covering circumference. I had to take this off as grille was too large with this on - simple to pull off.
  6. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    I'll give that a try too,has anyone got any large feet on theirs yet,i did get some soft rubber ones but were too soft.At first i didn't think that it made any diference but it has made a big difference to the sound.
  7. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Yes, I got a set of 4 black (approx 1inch high) from Homebase, for a couple of quid. Considerign sub is otherwise placed directly on thick pile carpet, it's definitely been worth it. Just sounds more controlled and snappier. Subtle but noticeable difference.
  8. mick23
    mick23
    Mar 20, 2002
    801
    uk
    ordered above grill from maplins yesterday afternoon recieved this morning, not had a chance to fit it yet,but would like to point out that grill is a "metal mesh" i was thinking it was a cloth type grill but should look ok when fitted ,
    re feet i tried some rubber feet cost 89 pence for three softish rubber door stopper type cones, but these are not stable enough.
    anyone got source for feet type cones to order online homebase/bq etc thank you
  9. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Grille material - I stated it was plastic because I beleived it was - maybe it has a plastic coating? Sorry if I inadvertantly mislead anyone. Liek I said, the grille made no impact (to my ears) on the sound characteristics. The rubber feet did. Mine were hard rubber - About £3, with holes in top to put screw in (they were designed as large door stops).
  10. jdanielp
    jdanielp
    Jun 20, 2002
    176
    Edinburgh
    how did you attach them to the Sub? presumably you didn't use screws?
  11. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Uncle Eric recommend some suitable glue. I did indeed use a screw....being very careful to screw into casing and nto THROUGH casing!!!
  12. knoxy
    knoxy
    Nov 6, 2002
    196
    Manchester
    +31
    screw? man, i don't have the balls to do that! think i'll stick with the wee rubber feet it came with :)
  13. mick23
    mick23
    Mar 20, 2002
    801
    uk
    funky monkey
    fitted grill tonight but found domed shaped of grill touches the V of vx10 trim when replacing with mesh in place, and leaves an unsightly gap of about 4mm between face of sub and trim, did you find the same, i have ordered the correct mesh and removed rubber ring on mesh befor fitting, thank you
  14. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Yes, grill does touch the V. However, I did not notice an unsightly gap. I have cherry sub - I don't know if this means the gap is less noticeable???? Anyway, you coudl always go with cloth grille, but for me whole point of metal/plastic grille is that my kid(s) can't poke their feet or fingers into the cone.
    I'm sorry if this suggestion doesn't meet with your expectations :( , but I found it to be an ideal, if not perfect solution. :)
    As for screwing the feet, I'm handy with DIY, and I was sensible enough to screw intou casing, not THROUGH it!!! :rolleyes:
  15. mick23
    mick23
    Mar 20, 2002
    801
    uk
    fm
    i did not mean to imply your info re grill was not usefull or a good idea, have now fitted mesh and it does look better than without,and of course makes driver less prone to accidental damage etc thank you
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Guys i thought the VX10 came with a cover? Am i missing something?
  17. FunkyMonkey
    FunkyMonkey
    Dec 11, 2002
    1,491
    48
    +83
    Mick23, I know you weren't criticising, I just don't want anyone to order a useless item! Not that is. It isn't. :rolleyes:
    Anyway, HornyDragon, The VX10 comes with a plastic cover - this covers some of the grill but you can easily get very large items through to the cone, e.g. Kids kicking it, prodding it, etc. Plus dust looks unsightly, and frankly, who can be @rsed to clean it?
  18. kilobulb
    kilobulb
    Jun 27, 2003
    452
    North London
    +13
    can anyone tell me what type of screw driver you need to remove the screws?
  19. mick23
    mick23
    Mar 20, 2002
    801
    uk
    kilobulb you should be able to purchase a screwdriver set at modest cost at woolworths ,the type that comes with various screwdriver bits, the type for vx10 screws is hexagon shaped.
  20. kilobulb
    kilobulb
    Jun 27, 2003
    452
    North London
    +13
    ok thanks
  21. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    Its an allen key screw and the cover is mdf not platsic,be very carefull when fitting the cover it does but a bit of strain on the v.
