D
Deleted member 24354
Has anybody come across these or used them ? I know that work in Australia, wondered if they work in the UK
VDSL2 SFP Modem for Telco
Did you every try this, I've been doing some research and seems an excellent way to get rid of my open reach modem and connect direct to my UDMPI actually found it on another forum where they are used in Australia but they didn’t say how you configure them for your ISP. What they did say is they do actually just plug them directly into the SFP ports of routers like UDMPs and they just work.
Most I have seen seem to report significantly lower sync rates. Have you seen any which have before and after comparisons with the BT or another router?I have seen several Ubnt threads where people are using them with BT VDSL products.
