VCR with S-Video Out
Discussion in 'Digital TV & Video Players & Recorders' started by Azrikam, Oct 27, 2003.
Tags:
  1. Azrikam
    Azrikam
    This may be a completely stupid question, but cabling is definitely one of my weak points.
    Is it common, or even possible to get a VCR with an S-Video Out connection? Basically, I've got some old NTSC videos that I want to convert to digital format. I've got a WinTV-Theatre card with S-Video in. My old NTSC VCR just recently died, so I was looking to pick up a cheap box to convert the tapes. I was going to do the audio as a separate process, so that doesn't really matter.
    Should I even bother with S-Video Out, or get some sort of convertable scart cable?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    The only VCR's that will have an S-Video port are SVHS VCR's. No standard VHS VCR's will.
    www.maplin.co.uk
    Product code: QM52G
    SVHS-Phono Adaptor £4.99inc
    Converts s-video to composite or vice versa. Simply connect in line. Composite end has single phono (RCA) socket, S-VHS end has 4-pin miniDIN socket.
    · Bi-directional conversion
    · Gold-plated connections
    · Compact and easy-to-use
    You will need something like the above product to convert a standard composite lead to S-Video so you can capture to your PC with a standard VHS VCR. Without this the picture will be in B&W.
    SVHS will give a better PQ, but this is obviously down to the quality of the origional footage.
    Mark.
  3. Azrikam
    Azrikam
    The original tapes are in pretty rough shape, so SVHS would probably be wasted.
    Thanks for the converter info. I'll pick one of those up and look for a low-end NTSC compatible VCR. (I've already got a good PAL machine)
