VCR with RGB Output
Discussion in 'Digital TV & Video Players & Recorders' started by meansizzler, Jan 15, 2008.
Tags:
  1. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    DO they exist, need one for archiving some tapes onto the PC...., so need a vcr which can output the best quality...
  2. bsuttie
    bsuttie
    Apr 4, 2006
    1,545
    63
    Edinburgh
    +206
    I think the best you'll get is one with S-Video out. As VHS is a colour under system the chroma is already combined.
    Use a TBC for best results - you could go S-Video into a TBC then component / RGB into your PC depending on what input you have.
    If you don't have access to a standalone TBC a lot of DVD recorders do a pretty good job of stabilizing VHS footage.
    regards
    Brian
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,687
    Somewhere in South Yorkshire
    +6,253
    Indeed. There would be no point, so no such thing exists (afaik). Agree with all that bsuttie says.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,531
    Rainham Essex
    +2,517
    A tape recorded on a VCR will only be recorded in composite video, so even if you could get a VCR that outputs RGB there would be no quality improvement due to the low quality of the recording.
    So to record onto the PC any standard VHS VCR will output as good quality as is possible from a VCR (as long as it is working ok). All you need is a good capture card to get the best capture. Or just a standalone DVD recorder will make good copies of the VHS tapes - as long as they are not copy protected (prerecorded) tapes.
    Mark.
  5. NST
    NST
    Feb 7, 2007
    366
    28
    Bedford
    +57
    There was a Philips Matchline S-VHS machine (VR813) from the early nineties that could be set to output RGB in the setup menu. The picture in RGB wasn't that great as it tended to enhance the flaws in the VHS format (such as poor blue colour reproduction and dot crawl etc).
    It was quite a feature packed machine in its day, as it also had an on-board Fastext decoder, which meant it could record and play back subtitles and teletext pages from S-VHS recordings. You could even use it to set timer recordings via Ceefax by selecting the desired program with a cursor :cool:
  6. nvingo
    nvingo
    Nov 29, 2007
    3,110
    Cambridgeshire
    +688
    Yes I had one of those.
    At the time there were few TVs with a S-video input, so to gain any benefit from S-VHS recordings on a TV with choice of RGB or Composite input, RGB was offered as an output.
    Also the user interface was pin-sharp connected this way.
    I don't see any benefit converting VHS or S-VHS to RGB for a PC capture card - I thought that most were capable of CV or S-video input, and that S-video (from a S-VHS VCR) would offer the best that either VHS or S-VHS can achieve.
