VCR Recording Subtitles Help
B
betamac
Hi there i am looking for a VCR which has built in teletext viewer in so i can record subtitles
can anyway please direct me to a place where i can buy one, Any make model or price it does not matter
gringottsdirect
Not latest model range so drying up everywhere but records colour subtitles from teletext very well.....Panasonic NVF-J710.
B
betamac
Thanks for the reply i found the NVFJ710BS for £199 is that a good price as far as you know?
gringottsdirect
As usual answer depends...
Is it from a shop or mail order ?
Is it brand new unopened stock ?
It is a very well built machine with a good specification, it is not part of Panasonic's new range, I would pay £199 for brand new unopened stock from a shop, otherwise £150 would be more to my liking.
MarkE19
TiVo can record subtitles once the automatic software update has been done!(normally within 2-3 days of setting up)
All you need to do is record a program as normal, and when playing back go to text page 888 to display subtitles. If somebody else watches the program and does not want/need subtitles then they are not automattically displayed (best of both worlds!).
TiVo can be purchased for as little as £150 plus £10 per month or 1 off £200 lifetime sub. The sub pays for software updates and TV listings (EPG).
B
betamac
Superb to be onest i did not realise TIVO had come down to £200 thanks alot i will go see if i can find one
B
betamac
Looked at most the popular sites i know and i cant seem to locate one, can you direct me to a website?
gringottsdirect
www.comet.co.uk
In store if you can find one too, they are dumping them like everyone else it seems.
MarkE19
If for some reason you can't get one from Comet then try NTL as they are selling them at (IIRC) £200
MonkeyDonkey
I have the NV-FJ710 its a great VCR, full of wonderful functions. I think £199 might be a tad high though, I believe mine was around £180 when I was given it in Jan.
Also would I be right in assuming these Tivo's require a subscription of some sort?
gringottsdirect
Yes, a Tivo subscription is presently £10 per month, this could increase, decrease or stop....or stay the same indefinitely.
You could buy a one-off Lifetime subscription for £200.
MarkE19
Yes it does require a subscription, but that works out at £300 for a unit that is far superior to any VHS machine. And with the benefits of never needing to find space on a tape and never needing to buy a TV listings mag etc. etc. etc........:)
