VCR recomendation required
Discussion in 'Digital TV & Video Players & Recorders' started by Mike Swannick, Jun 23, 2004.
Tags:
  1. Mike Swannick
    Mike Swannick
    Can anyone recommend a decent S-VHS VCR. My requirements are;
    Preferably silver
    Preferably Toshiba (used to the layout thats all)
    Preferably not too expensive
    It is a stop gap before a DVD recorder that will go onto to be used as a capture source for home video footage.
    Cheers,
    Mike. :thumbsup:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,437
    Rainham Essex
    +2,470
    IMHO the only VCR's that are currently worth getting are JVC & Panasonic and I'm not sure if any other makes even make SVHS VCR's.
    If replaying old tapes then you would be best to go for a slightly more expensive VCR that has a Time Base Correction (TBC) feature as this can improve the PQ by a fair amount. You should not need to spend any more than £150.
    Mark.
  3. Mike Swannick
    Mike Swannick
    Cheers Mark. JVC or Panasonic are fine (Toshiba option was just so that the format was 'familiar' to one half of the marriage :rolleyes: )
    Can you suggest a couple of models that come recommended?
  4. paul710
    paul710
    Feb 16, 2004
    34
    Bolton
    Got my Panasonic NVSV120 7 months ago for £130 and I have been surpised just how good the S-VHS performance is - would recommend this machine to anyone. I think it has just been replaced by another model (NVSV121) which I have seen for £150.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,437
    Rainham Essex
    +2,470
    Yeh, thats a real problem. The models just get update so quickly that somebody who bought a VCR 6 months ago would now have little idea about the current models. There again they only tend to make a couple of models of VCR these days so just decide on the features required ie Nicam, TBC, SVHS etc and I think in most cases there will only be one or two models per make.
    Mark.
