VCR problems connected to Pace Twin
Discussion in 'Digital TV & Video Players & Recorders' started by wattsj, Dec 28, 2003.
Tags:
  1. wattsj
    wattsj
    Apologies if this has been discussed already but I've just got a Pace Twin and have connected it up as shown in the manual.
    Now I cannot view the picture from my VCR !
    It's connected through the Pace but doesn't seem to pass the signal through, any ideas ?
    Jay
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Sell the vcr on Ebay
  3. colin_e
    colin_e
    Dec 6, 2003
    56
    Nr. Reading, UK
    +4
    Just checking- you haven't connected to an input-only SCART on the VCR have you? If your VCR has dual SCARTS make sure you are connected to the right one.
    Also, I assume you are selecting AUX on the twin, and have a fully-wired SCART from the Twin to the VCR?
    It could be that your TV is not auto-detecting the switch from RGB output on the Twin (assuming you are using RGB) to composite. Try manually selecting composite in on the TV.
    Also if your VCR uses S-Video out you will need to connect it directly to an S-Video compatible port on your TV. Switching can get complicated :-}
    Good luck- Colin
  4. chilpillphil
    chilpillphil
    or you could connect your vcr to the tv using another scart lead, if theres a spare SCART on the tv.
    or run an RF cable to the tv and tune the VCR in on CH 08 or whatever
