VCR Output Problem
Discussion in 'Digital TV & Video Players & Recorders' started by RemotecUK, Jun 23, 2004.
Tags:
  1. RemotecUK
    RemotecUK
    Mar 18, 2004
    54
    Birmingham
    Hi, Ive "borrowed" my parents (approx). five year old Sony video to watch some of my old tapes - this has now been installed into my rack :)
    I thought the best way to connect it would be to get a Scart to S-Video convertor and plug this into the AV amp which then routes the signal to the screen.
    This works but the picture I am getting is in black and white. Im guessing that the VCR doesnt have RGB output on scart. Am I right?
    I dont really want to buy a new VCR for watching old tapes recorded from the TV so could I get a scart to composite converter, plug this into the amp and will it give me colour pictures?
  2. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    As far as I know, RemotecUK, RGB output doesn't exist on consumer-level machines.
    A SCART cable will give you a composite output or, if it is aptly wired and you have the appropriate s-video output (VCR) and input (TV), you'll be able to view the significantly clearer (on my set, at least) s-video image.
    If you are connecting to an amp/receiver, you'll just have to decide which connection you wish to use and check what is possible with the amp. I believe that some boxes can provide an s-video output from a composite input, for instance; but, as I said, you'll have to check the details - or wait for some friendly type to confirm the facts... :)
    Finally, in terms of s-video, there is one more matter to bear in mind: signal direction. S-video cables are said to be 'directional', meaning that they can be either 'input' or 'output'-enabled. Use the wrong type, of course, and you'll garner results along the lines, for example, of a black and white image.
    Hope that helps :smashin:
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    A scart plug carries various video signals, but only the ones the source is wired to send. Just cos there's an s-video plug on the end of a scart doesn't automatically make an s-video signal appear. A VCR is composite video only. S-video uses the same pins as composite to send the 'lumiance' 1/2 of the signal, 'chromiance' or colour information is sent on different pins, allowing more bandwidth and more quality. The s-video capable display is displaying just the lumiance, ie how light or dark. As you see, this is b/w. You can buy a device to upconvert composite to s-video. It adds no quality, just compatibility. Some recent amps do this for you too.
    BTW you would get exactly the same result from a RGB device, you need a converter to turn that into s-video, decent quality there though.
  4. RemotecUK
    RemotecUK
    Mar 18, 2004
    54
    Birmingham
    Interesting, when I was looking for an amp up-video conversion was on my list of must haves. However, through severe personal incompetence I didnt actually think about it when I selected my amp (Marantz SR5400).
    I havent seen that function in the instruction manual so I am presuming it doenst have the feature.
    Can someone suggest the cheapest way to get colour images from the video's scart output via the amp?
  5. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Scart to composite lead, £10
