VCR FFWD and Rewind Emulation on Pronto
Discussion in 'Home Cinema Control & Remote Controls' started by Kevo, Feb 10, 2002.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,444
    Manchester
    +166
    On my JVC VCR remote (and most other maufacturers) you can either press, hold and release the FFWD and REW button for more precision or tap them quickly to search.
    These two methods are very useful and was wondering whether the Pronto emulates these actions.
    If it doesn't then I don't think I'll bother in investing in one.
    Many Thanks.
  2. mjn
    mjn
    May 24, 2001
    23,484
    Herts, England
    +11,870
    i have sony VCR and DVD, and you can learn the pronto to do either 1 press, or continous pressing.
  3. Kevo
    Kevo
    Aug 23, 2001
    5,444
    Manchester
    +166
    Using the same icon or do you have to have seperate icons for each function?
  4. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    With my Tosh VCR if I tap the FF it fast forwards at a slow rate, but if I hold the button then it doubles the rate. My Pronto works in exactly the same way, on a single learnt button.
    Hope this helps.
  5. Gary D
    Gary D
    Jan 9, 2002
    7,786
    +838
    the pronto is the best gadget you will ever buy!!! Every programmed button works exactly the same as on the orginal remote, go and buy one you will be amazed!!
    Gary
  6. mjn
    mjn
    May 24, 2001
    23,484
    Herts, England
    +11,870
    just the one button!
  7. Kevo
    Kevo
    Aug 23, 2001
    5,444
    Manchester
    +166
    Thanks a lot guys.
    You've just sold another Pronto !
