VCD wont play?
Discussion in 'Desktop & Laptop Computers Forum' started by fastercainy, Jul 23, 2002.
  1. fastercainy
    fastercainy
    ok jeff (the mod)deleted my last thread said somthing about illegal activity going on or or summet i didnt read it all *YAWN*:D ok how do i get my pc to play VCD?do i need a programm ar a patch of somekind :confused: i hope this question is not illegal to ask:D
  2. Ron240
    Ron240
    Jan 3, 2002
    3,617
    Kirkcaldy (but i'm not a Fifer)
    +466
    You do need the appropriate software to play VCD's on your PC.If you have a DVD drive then the software that came with this should do it,Power DVD is a good one. Also Windows Media Player should work - look the drive with the VCD in it,find the MPEGAV folder and click on it then click on the .DAT file and open it using Media Player.
