VCD players better then DVD players at VCDs playback?
Discussion in 'Blu-ray & DVD Players & Recorders' started by HighlandeR, Aug 18, 2001.
  1. HighlandeR
    HighlandeR
    Im hearing that VCD players are far better then DVD players when it comes too VCD playback in terms of picture/sound quality.
    Is this remotely true?
    I heard 2 people say theres no pixely squares or slow downs or errors with VCDs at all with a proper vcd player unlike dvd players....
    Ive seen some 60 quid good quality VCD players as well !
  2. glen61
    glen61
    ive got some VCD films as well as music ones <br />supplied by <a href="http://www.mcno.com" target="_blank">www.mcno.com</a> .<br />there no way as good as DVD as far as picture quality and sound.<br />the only thing there good for is kareoke ,which MCNOES have plenty off.<br />still worth a look .<br />-------glen61--------<br /> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
  3. HighlandeR
    HighlandeR
    Thats what I thinking the VCD is just mpeg1, even played back on a Pc its still pixely/blocky even with the latest software/firmware.
    So I doubt a VCD player will play it any better.
    VCDS are poormans films, while DVD is the class <img src="smile.gif" border="0">
  4. eros
    eros
    I have a wharfedale 750 DVD player and a philips 210 cdi player. The picture on vcd's is better on the phillips.
  5. hobbes
    hobbes
    To be quite honest it is a bit of a mad question here.
    VCD players are better at playing VCD's than DVD players. This should be obvious as A VCD players median is the VCD. A DVD players median is DVD.
    Thats like saying that 'i've heard CD players are better at playing CD's than DVD players'.
    Think about it.
  6. HighlandeR
    HighlandeR
    Yeap thats what I thought at first.
    Guess ill have too wait till I can test it out myself on a VCD player !
    If this is the case I wanna know just how good the picture/sound is !
  7. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    ROTFL.
    Acutally in the early days it was said DVD players will beat VCD players, but anyhow, the limitation is the VCD format and not the player.<br />I have seen all kinds of VCDs but most do suffer from pixelation due to the MPEG-1 encoding and some VCD players seem to soften the image.
    IMHO crap and not worth considering unless you live in Asia where (pirated) VCDs cost less than 1 pound.
    [ 19-08-2001: Message edited by: Reiner ]</p>
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Depends how you compare it, the difference between CD playback and DVD differ mainly in terms of the DACs used while VCD should be an easy thing to do since DVD (MPEG-2) is backwards compatible and can therefore decode VCD (MPEG-1), too.<br />So where should a VCD player have an advantage then? It can not make the picture look better as the source is already limited.
    Anyhow, the fact remains that VCDs are crap. I did not invest in all that surround sound equipment and then feed it with inferior software ...
  9. HighlandeR
    HighlandeR
    Yep was gonna raise that point also.
    Heck the PC has all those players and even in high resoultions and it still plays it pixely/blocky!
    Ill still check my mates vcd player naturally!
