VCD editing
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by tyler07, Nov 16, 2003.
  1. tyler07
    tyler07
    May 20, 2003
    34
    9
    *Sorry if this is in the wrong folder.
    I have a few video files on cd-r' which won't copy to the HDD. I get an error message part way through the copying (invalid ms-dos function or something).
    One file has an error at around 30mins (ie. video stops) but before and after that point it plays fine on my pc.
    What programs are there that will let me edit the file and maybe split it into 0-29mins, then 30-120mins?
    Any help/links much appreciated.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Hi tyler07 and welcome.
    What OS are you running on your PC?
    If it is Win98se then you HDD is formatted to FAT32. Even if it is XP etc then the disk could still be FAT32 and needs to be converted to NTFS. FAT32 will mean that the biggest file that Windows can read is 4GB. If the software you are useing is a standard editing prog then it could be converting it to AVI as copying and therefore around 20 minutes of video will reach the 4Gb limit.
    Give us the specs of your PC and the software/OS you are useing and we might be able to give more help and/or suggestions.
    Mark.
  3. tyler07
    tyler07
    May 20, 2003
    34
    9
    Thanks for the reply.
    I'm on Xp and not using any programs to copy, simply grabbing the video file off the disc (around 700mb) and dropping to a folder on the HDD.
    Is there any software that will let me seperate the video file and then join again without the fault?
  4. stormchaser
    stormchaser
    Nov 19, 2002
    450
    +10
    hi
    if you have xp ,then you could try windows moviemaker2
  5. Brian110507
    Brian110507
