VB Gettig BAD on AE700
Discussion in 'Projectors, Screens & Video Processors' started by jjdaugh, May 20, 2005.
  1. jjdaugh
    jjdaugh
    After a few hundred hours the VB is getting really bad on my AE700. Doing the flicker tweak helps but I am having to do it all the time.
    What I dont understand is why it takes the local service people two weeks to update firmware. I should be able to walk in and have them do it on the spot in about ten minutes.
    What a total pain to take it in for that. We use it as our primary tv with tivo etc.
    I am running 1.05 firmware...
    Jim
  2. thfccambs
    thfccambs
    Jul 17, 2002
    19,151
    White Hart Lane
    +5,264
    Had bad VB on mine with skysport using firmware 1.03.Had i updated to 1.07 and it excellent.Happy chappy now just might have to sell it as im looking to move. :suicide:
  3. pmc
    pmc
    Oct 18, 2004
    1,411
    +109
    Interesting. I am also having increased VB after a couple of hundred hours, and most noticably on Sky Sports watching footy. Looks like its time to send it back, but your right, it sucks having to wait 2-3 weeks for service.
  4. David_of_Surrey
    David_of_Surrey
    Oct 13, 2004
    200
    +6
    I suffered a loss of picture quality and all it needed was for me to clean the filter (it was on 130 hours) this fixed it . So I guess this was a heat problem. I only get VB (firmware 1.03) if I forget to turn the projector off (with the switch) otherwise OK
    Dave
  5. nigelbb
    nigelbb
    Apr 4, 2005
    5,269
    103
    +490
    It only takes a couple of minutes to upgrade the firmware. You need a special 9 pin serial to 15 pin VGA connector. I don't undertand why Panasonic Customer Service should require the projector for 2 weeks.
  6. jjdaugh
    jjdaugh
    The US version doesnt have the SCART connector.
    Also, I bought my PJ from projectorpeople.com. Sarah Buss is AWESOME.
    Anyway, they told me people have improved VB if they pull the power from the unit periodically. I did that last night and it helped but not 100%.
    Jim
  7. FoxyMulder
    FoxyMulder
    You have to give the unit at least 30 minutes to warm up before you adjust the flicker settings in the secret menu, after that leave it and never change those settings and you will find it improves things.
  8. ptek
    ptek
    Do you have any info where to get "special 9 pin serial to 15 pin VGA connector" Ta :)
