Vauxhall OEM Display
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by hornydragon, Feb 23, 2003.
  1. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Does anyone know of HU that will work with Vauxhall OEM display unit, I know Kenwood D-Mask units will but they are too much, looking for a single CD or a HU with autochanger control, MP3 not necassary but display compatibility is. For the Missus Corsa like. Not fussed on tape so CD or MD and Sub £200 if you know of any where that can.
    PS I just lost my ICE Virginity so be gentle
  2. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    If you are refering to the display with the time, temp etc then they all will.Only thing is when the h/u powers up then the date will vanish ( who the hell needs to know the date while driving ?:confused: ), it will return when you switch off the h/u again.If you want to retain it then cutting the signal wire is nessesary iirc it's red with a white tracer but i can find out if you wish.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    She wants to keep that display as the DIN slot is a bit low to see which track etc is being used. It's a minor thing but you know women. the simplest thing is to buy a vauxhall HU but they are so overpriced its not funny. Might try and get one from a scrappy or a dealer that does P/X on installs.
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Doesn't anyone ever searce the internet
    www.connects2.co.uk
    And they work well I have a DOPST002
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Pre funny H/U Omegas use DOPS002
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Thankyou Martin much appreciated.
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Sticky message I think!
    This gets asked all the time
    My MD Deck displays happily on the Vauxhall display!
    I have the full display with fuel consumption and range!
  8. minimad
    minimad
    Doing a search will bring up this thread. I don't think it needs a sticky.
    Collin
  9. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
    Exactly.
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    OK guys she got round to actually getting one but getting quoted silly money Kenwood 6024 is hiigh on the list but the adapter is £80 plus fitting so it pushes the budget over the top!!!!!!
    Martin Where did you get your DOPS unit???? There is a place at pennsnette but do they do retail??? and how much are they????
    Out of these
    Kenwood
    And Sony
    What do you think?? anyone own one of these???
    I need some help!
  11. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Seen them at Sony centres and Halfords I think
    Sony MD decks are ok, well mine is - better than the Delco CD I removed.
    Sony MDX ???? 5970
    DOPS002
    Infinty 605cs
    I may get a CD changer next!!!
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    cool My missus thought that an MP3 deck (CD) would be enough for her a CD/MD changer was over the top and too expensive
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
  14. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    DOPS 001 has been dropped - for the temperature only displays
    DOPS002 is not much more and supports the full display
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Cheers martin i was quoted £60 for an adapter from a different company today!!!
    Any idea how much they are?Thinking of a Sony CDXMP40 which is £145 online, or 169 in a local dealer.
  16. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    Mine was £70
    as to DOPS001 it is worth getting 002 if you swap the car.
    As to head units I'm afraid I don't know
  17. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Well thats al right then, this is starting to look expensive!
    Sony CDXMP40 £125 + £10 del
    VAU01DIS Display interface £60
    or
    DOPS002 still looking for a retailer! £60 approx
    PC2-04-4 Harness Adapter £11
    PC5-27 Aerial adapter£3 (not sure if i need one of these)
    Total parts! £210 ish and i have to fit it myself! Alot for a £130 CD player.LOL
    Thanks for the help guys i wont be fitting it for a couple of weeks as i have exams until the end of the month but I am sure I will be needing some help to fit it when i do. Unless of course i can get it fitted for under £230 i which case i'll pay the difference!
  18. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    DOPS002 is mail order
  19. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    I have mailed halfords and i will call the distributor when the time comes! at least i have a definite price now! This is going to turn into a nightmare!
  20. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    I think the cable adaptor may be included with the display driver, if I remember right
    H/U ->
    Supplied cable with H/U ->
    Display Ad Cable ->
    Car wiring
    Dispaly driver also plugs into CD connector
  21. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    Cheers martin!
  22. hornydragon
    hornydragon
    Dec 19, 2001
    28,291
    +1,217
    An extract from an email from halfords:
    Thank you for contacting Halfords Direct.
    The Sony CDX-MP40 is priced @ £199.99
    The PC2-04-4 is priced @ £10.99
    The PC5-28 Is priced @ £4.99
    The DOPS002 is priced @ £50.00
    These items may need to be ordered in on special order
    So i have got the DOPS002 down to £50 which is bettter, i wouldn't buy the HU from halfords but the cables are competitive!
  23. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    My DOPS002 was £70:(
