Varilight and Ceiling Fans
Discussion in 'Home Cinema Control & Remote Controls' started by noshoulders, Aug 3, 2006.
  1. noshoulders
    noshoulders
    Apr 5, 2005
    451
    28
    +29
    hi guys, i bought a Smith's TimeGuard IR light switch from maplins. http://www.maplin.co.uk/Module.aspx?ModuleNo=32372&criteria=ir light&doy=3m8
    Apart from it being ugly and sticking an inch out from the wall it's a dimmer and doesn't work properly with my ceiling fan/light. The fan emits a buzzing noise and doesn't spin to the speed it used to with an ordinary on/off switch.
    Is anyone using the Varilight switch with a ceiling fan and does it work properly?
    thanks
    Noshoulders
  2. rhino2k
    rhino2k
    Oct 20, 2005
    6,105
    +1,305
    you're lucky you have not had the switch catch fire :eek:
    you cannot use the dimmer with fans, it will be quite clearly stated in the instructions!
    it will be fine for running the light but do not try and use the fan ;)
    p.s if you have kids/wife it may be best to disconnect this altogether and replace with the std switch. potential fire hazzard, you have been warned :smashin:
  3. noshoulders
    noshoulders
    Apr 5, 2005
    451
    28
    +29
    yes i have already switched back to the standard switch, could not do without the fan during the recent heatwave.
    Do varilight do a normal non-dimming IR switch?
