Vandamme Component Cables...
Discussion in 'Cables & Switches' started by GafferTape, Oct 19, 2005.
  1. GafferTape
    GafferTape
    I've just received my Vandamme components I've bought through Ebay, and I've got what is probably a bit of a silly beginner question.
    I was under the impression that component cables are of the Green, Blue, Red socket colours. Yet the ones I've received are Red, White, Black.
    I'm guessing that it doesn't really matter (if that's the case, which is green and blue, white or black?), but I just want to make sure.
    :confused:
  2. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Hmm sounds like you have been sent standard composite and phono cables (which are cheap/poor quality in comparison to component)- got pics?
  3. GafferTape
    GafferTape
  4. lee_car
    lee_car
    May 16, 2005
    579
    Oldham
    hi i use these cables for my projector, all the component cables are the same inside just different colours, so you can connect the to any you wish eg red - red, black - blue, green - white, is there any colours on the connectors?
    lee
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,990
    The Borders
    +3,599
    GafferTape
    What part number is printed on each cable?
    The 'Plasma Grade' 75 Ohm comes in five colours:
    268-306-000 Black
    268-307-020 Red
    268-308-050 Green
    268-309-060 Blue
    268-310-090 Cream
    Best regards
    Joe
    PS If you'd bought them from a supplier who Advertises on the AVForums who recommends them you would have received one each of Red, Green and Blue to avoid any 'complications' :)
  6. GafferTape
    GafferTape
    Hey, thanks for your reply.
    All of my three cables are the 268-310-090 of the Cream variety.
    So just to clarify, am I alright with those cables?
    I dont thin I bought them from a supplier that advertises here, but rather a recommendation in one of the threads on cheap components linked me to an Ebay seller.
    Thanks for your help Joe.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,990
    The Borders
    +3,599
    Hello GafferTape
    Yes you can use these cables for YUV no matter which cable you use it'll be happy carrying a Red, Green or Blue video signal :)
    Best regards
    Joe
  8. rhino2k
    rhino2k
    Oct 20, 2005
    6,128
    +1,322
