Van Den Hul cable questions
Discussion in 'Cables & Switches' started by MJeeves, Sep 23, 2004.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Which end does the "GROUND" end go? Nearest the amp or nearest the source?
    Also, are Van Den Hul cables directional?
    Thanks.
  2. Filbert
    Filbert
    Apr 6, 2004
    962
    46
    Pinner
    +195
    Some cables that vanden Hul manufacture are directional, others aren't. Also we have had vdH cables in the past that had the ground sticker at the wrong end! With pretty much all cables, the signal flow should be in the direction of the writing on the cable. so as you read the writing from left to right, the source would be on the left, and the target on the right.
    I think, you'll find that the source sticker will be on the left as you read, and therefore the source end, which is correct.
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Is "GROUND" and "SOURCE" the same thing then?
    Thanks for your help. :thumbsup:
